 Photos of custom/modified EBB/Mini-Electric/LPEG
Next Page
Page: of 2
RLB
Death Dealer
Posted - 03/25/2005 :  4:55:04 PM  Show Profile  Visit RLB's Homepage  Reply with Quote
This is a PICTURE THREAD ONLY, no discussion.
No pictures of stock guns, Custom or modified ONLY.
Posted - 03/25/2005 :  9:49:21 PM  Show Profile  Visit justsomeguy's Homepage  Send justsomeguy an AOL message  Reply with Quote
Since all of you are so lazy...
http://www.airsoftretreat.com/forums/topic.asp?TOPIC_ID=69258
Statistics
FPS: 234.7
Total Range: 157 feet (Where it drops)
Effective Range: 80 feet
RPS: 19 (7.2) 23 (9v)
Hop Up: Adjustable
Length: Stock Extended: 25 inches
Length: Stock Retracted: 21.5 inches
Sights: Spec-Ops Style Iron Sights, Aimpoint Red Dot Mounted on Fore grip Rail
BB: 0.12 (Haven't used .20s yet)
Modifications:
Internal:
Upgraded to 235 fps
Disabled Secondary (Pistol Safety)
Foam Inserts, Quieter
Systema Short High Speed Motor
External:
Chopped up the Sight
Rails on top and bottom of hand guard
Commando Barrel Hack
Bigger Pistol Grip
REAL Fore grip
Trademarks
L.E. Stock
H.E. Coating
Edit: You guys wanted a EBB/LPEG photo thread. Post something.
crazyaznman
Posted - 03/25/2005 :  10:35:39 PM  Show Profile  Visit crazyaznman's Homepage  Reply with Quote
Just Some Looks I've Been Working On...nothing too flashy =p
Image hosted by Photobucket.com
Eddy72
Posted - 03/26/2005 :  2:29:57 PM  Show Profile  Visit Eddy72's Homepage  Reply with Quote
Free Image Hosting at <a href=www.ImageShack.us" />
***Now to get the pics bigger you press the graphic. If anything goes wrong i will try to figure it out. Good i think i got it working steady. If anything goes wrong with the pics let me know.***
---------------------Eddy's SR-16 style TOP M4A1--------------
Ok guys here is my new mod. I tried to make it as close to an SR-16 as possible without buying anything expensive.
----------------------Modifications---------------------------
* Retractable stock has been taken out in favor for a Solid M-16 Stock. Remember that crappy M-16A2 i told you about in my previous posts? Well now it had a purpose...To be salvaged into parts! To attach the solid stock first i took (slid) out the retractable stock. Then I took the already hollow M-16 stock and carved out a horistontal hole in the part where the stock meets the gun. It is difficult to explain but after i finished doing that all i did was slide it on and tighten the screws. Voila! It is on nice and snug. I put the tape there just so it looks like it molds into the gun more.
* The Flip-Up back Ironsight was also pretty easy. My TM AUG SR came with two flip up iron sights that acted as sights if you didn't have optics. Although not exacty the SR-16 flip-up sights, they were the closest thing i had. Simple weaver rail attachable flip up iron sight.
* Opened up gun because i wanted to upgrade the power. But to my misfourtune the spring is the smaller kind found in other EBB's, and full sized springs would fit in the piston. The only thing i could do was add a spacer... Not much power was increased. There is some noticable difference, but not nearly as much as i wanted.
********Edit: I now have added a spring from my brother's M405 spring pistol and put it in my gearbox. Combine this with a spacer and it shoots pretty hard now, i would say around 200 fps. This goes to show that TM HGHU's are not the only spring pistols that have small sized springs! Hurray!!!***************
* Top plastic rail bondoed and painted black. (Both the Red Dot and the flip-up sight can be on the rail at the same time, similar the the SR-16. This also allows for quick zeroing when the Red Dot isnt zeroed in.)
* Dissabled Secondary Pistol Saftey from the inside this time. No tape required.
* WELL Foregrip mounted onto another rail that was bolted on. Couldn't bondo the rail because of the lack of strength the bondo would support. Need to be bolted because of the constant pressure being applied to the foregrip.
* Removed Leather Grips. They needed to go when i took apart the gun. I like how the pistol grip feels now that the saftey is gone.
* Larger Flashiher has been added. Originally, i had the Commando Barrel Hack, but after i decided to mod my gun into a SR-16, it had to go. I did not want to put my original M4B barrel back together peice by peice bondoing (I had already chopped it up), so i salvaged my M-16A2 platic barrel and bondoed it as one peice. Wish i just kept the M4B barrel...
* NcStar 30mm Red Dot sight can be optionally mounted instead of the Flip-Up sight.
* Magazine spraypainted Silver/Chrome. Looks better than black to me.
------------------------MISC.---------------------
I never adressed this before, but my selector swith fell off a while back. When i opened my gun, I was able to tighted back on.
I know the paint-job is a little blothcy, but im not that big when it comes to being very presise.
Remember the old flashlight you saw? It can still be attached to the rail, but i went for the SR-16 look. I can always switch the Foregrip and Flashlight around though.
Remember the Masterkey you saw? I can always swith around the rails and mount it back on, but i wanted the SR-16 look.
Thanks everybody for looking. Original (aka, Crappy) projects can be found here (Oldest first, newest last): http://www.airsoftretreat.com/forums/topic.asp?TOPIC_ID=62509
http://www.airsoftretreat.com/forums/topic.asp?TOPIC_ID=62571
http://www.airsoftretreat.com/forums/topic.asp?TOPIC_ID=64492&SearchTerms=contest,results
Any questions, comments, suggestions?
Mr. Tippy
Posted - 03/30/2005 :  6:53:25 PM  Show Profile  Visit Mr. Tippy's Homepage  Send Mr. Tippy an AOL message  Reply with Quote
http://www.picturetrail.com/mkphred14 <--- my custom m4a1 boys aeg(before it was customized and after) also my custom mini m4(the picture is not up to date, i recently cammoed it like my m4a1 boys.)
MarksmanOne
Posted - 03/31/2005 :  1:27:32 PM  Show Profile  Visit MarksmanOne's Homepage  Reply with Quote
Image hosted by TinyPic.com
cyma mp5j with tokyo marui LE style stock. also added tokyo marui gears and tokyo marui spring from a boys gun. the LE stock is actually worth more money than the cyma gun heh.
sorry bout the pic quality.
Posted - 04/09/2005 :  09:39:28 AM  Show Profile  Visit justsomeguy's Homepage  Send justsomeguy an AOL message  Reply with Quote
Custom TM Glock 18c EBB
The grips are made by Hogue Inc. They're great. Real comfortable and when you sweat, it soaks it right up. Good thing is that it wont disengage the safety so you wont shoot yourself. It's a really tight fit and takes a lot of strength to put it on. 10 bucks. I think it was a great investment.
Tactical Sights (Uber) made by cut mailing labels
Spartan XV
Posted - 04/19/2005 :  3:12:56 PM  Show Profile  Visit Spartan XV's Homepage  Send Spartan XV an AOL message  Click to see Spartan XV's MSN Messenger address  Reply with Quote
My Custom "Bad Boys II" TM G18C EBB
Zephyranthes
Posted - 04/30/2005 :  9:31:38 PM  Show Profile  Visit Zephyranthes's Homepage  Send Zephyranthes an AOL message  Send Zephyranthes a Yahoo! Message  Reply with Quote
My custom mp5 mini. Has the punch of a spring pistol. It shoots 960rpm (16 rounds per second). That's faster than some aegs. Holds a 36 rounds spring fed magazine. Upgraded motor, 12v 1800mah battery. Full stock. Has a longer barrel from an XM177E2
http://webpost.net/ze/Zephyranthes/DCP_0359.JPG
http://webpost.net/ze/Zephyranthes/mini2.wav
Grigio
Philippines
Posted - 05/05/2005 :  02:16:39 AM  Show Profile  Visit Grigio's Homepage  Reply with Quote
just passing by....
http://img.photobucket.com/albums/v634/grigio/RPK1.jpg
http://www.naax.net/racir/DCP_1286.JPG (posting for a friend)
http://www.naax.net/racir/DCP_1154.JPG (posting for a friend)
Eddy72
Posted - 05/25/2005 :  1:49:35 PM  Show Profile  Visit Eddy72's Homepage  Reply with Quote
I was noticing that no one is posting anymore custom guns, so I decided to give it another swing. Plus I was bored
--------Behold!!! My Ghetto Full-Size Mini M4A1!!!---------
Overall view of the masterpiece
Better view of the masterpiece
Close up of Ghetto Cardboard (but still strong) Silencer
Close up of Retractable stock
Ghetto Mods:
* Retractable stock bar hot glued to the but of the Mini. The stock itself is friction fitted on (pretty snugly I might add) and can be moved up and down, but still maintain its hold. Gets the job done!
* Block of Wood hotglued to the bottom of the mag. The block makes the Mini mag look extended. Kinda looks like a 9mm conversion dosnt it?
* Silencer hotglued on the barrel (at the sides). Silencer made out of strong cardboard wrapped in duct tape, then spraypainted.
And there you have it! There is nothing that spraypaint/tape/hotglue cant do! Any questions, comments?
crazyaznman
Posted - 06/18/2005 :  12:55:16 AM  Show Profile  Visit crazyaznman's Homepage  Reply with Quote
Hey guys just added some new stuff externally to my M4 so decided to post since no one has posted in a while =p
FuBaRSliz
Posted - 07/01/2005 :  9:18:02 PM  Show Profile  Visit FuBaRSliz's Homepage  Reply with Quote
My custom made m203 Grenade launcer made for my freedom fighter I used the handle off my broken sd6. I know its missing a trigger and guard gonna add it later.
Skeletor
Posted - 07/15/2005 :  12:53:42 AM  Show Profile  Visit Skeletor's Homepage  Send Skeletor an AOL message  Reply with Quote
http://hometown.aol.com/imaheratic/myhomepage/dsc01441.jpg?mtbrand=AOL_US
http://hometown.aol.com/imaheratic/myhomepage/dsc01442.jpg?mtbrand=AOL_US
tell me what u think eh?
pennywise
Civilian
South Sandwich Islands
Posted - 07/15/2005 :  01:13:09 AM  Show Profile  Visit pennywise's Homepage  Reply with Quote
I only yoose it wen im bbeeng d3lta froce
Posted - 07/17/2005 :  04:04:52 AM  Show Profile  Visit justsomeguy's Homepage  Send justsomeguy an AOL message  Reply with Quote
Come on guys. You b!tch3d so much about not having one of these. Now that we have it, you dopn't post a thing. Put something in here. I think the only people who have posted something didn't ask for this. Well I didn't think of posting this, but maybe it'll make you guys start doing something.
Custom Boys M4 Version 5.0
Statistics
FPS: 234.7
Hop Up: Adjustable
Modifications:
Internal:
Upgraded to 235 fps
External:
Bigger Pistol Grip
REAL Fore grip
Trademarks
L.E. Stock
H.E. Coating
New Paintjob/Parts
Double Mag Clamps
Six-Postition Stock (instead of 4)
http://www.airsoftretreat.com/forums/topic.asp?TOPIC_ID=71911
Sound file:
If anyone is interested in the ROF of this gun, I recorded it. Unfortunately, it was on low battery. Its charging right now. I might make a new one, but in order for you to hear the sound, I have to stick the mic up the mag well, which means i have to dry fire it.
And yes, the screeching sound is the motor.
And now, courtesy of Illicom (who I now love), here is the file:
http://www.airsoft-online.8m.com/M933.MP3
Posted - 07/17/2005 :  04:08:18 AM  Show Profile  Visit justsomeguy's Homepage  Send justsomeguy an AOL message  Reply with Quote
Tokyo Marui Glock 18c EBB
*Hogue Grips (Hogue Handall)
*Real Steel Glock Sights
*Threaded Barrel Replacement
*Silencer
http://www.airsoftretreat.com/forums/topic.asp?TOPIC_ID=71079
Does anyone else have a modified EBB out there?
doofus333
Posted - 07/17/2005 :  1:21:18 PM  Show Profile  Visit doofus333's Homepage  Send doofus333 an AOL message  Reply with Quote
my masterkey. the superglue was a mistake, so at some point, i'm going to completely redo this. actually secure it with something, you know, secure. oh, and hack the grip off the shotty. and paint the hell out of the whole thing.
Eddy72
Posted - 07/19/2005 :  10:29:32 AM  Show Profile  Visit Eddy72's Homepage  Reply with Quote
My current M733 Navy Commando
* 2 more heatsheilds (homemade) added to the top and right side of handguard. I used HotGlue to keep them Secure. (I didnt feel like wasting 30 dollars for 2 heatshields).
* M733 Barrel Hack.
* Knight's SR-16 M4 Logo added. It is just Computer paper glued on to the reciever. It looks pretty real from a distance :). I also used white out to fill in 'safe semi auto'. Yes i know it is messy...
* Magpuls (on both Mags).
Armalite Fever Baby!
DJMikeOz
Posted - 07/21/2005 :  10:16:28 PM  Show Profile  Visit DJMikeOz's Homepage  Click to see DJMikeOz's MSN Messenger address  Reply with Quote
Taurus PT92 EBB Now Available At Some Wal-Mart Locations
Converted to full auto and painted the slide with a mix of Rust-Oleum over (still Tacky) Krylon Fusion Satin Finish Black.
Topped it all by painting the safe/fire indicator red and the front sight white.
Now all I have to do is add an LED inside so it lights up when you pull the trigger.
DJMikeOz
Posted - 07/24/2005 :  09:35:02 AM  Show Profile  Visit DJMikeOz's Homepage  Click to see DJMikeOz's MSN Messenger address  Reply with Quote
Edit:
Kayo, I'm done with this one (for now).
Before;
Incomplete M4 "Freedom Fighter" Mod
Now to present My finished M4 "Freedom Fighter" CQB Assault Mod.
After;
I finally finished the paint and I added "Authentic Trades" LOL.
Now all I need is a 9v and a Hi-Cap, hehehe.
Thanks go to Eddy for giving me a kick in the pants to finish it, because, frankly it was ugly. I like it better now.
New Pics as of 7-27:
Re-mounted the sling to the bottom of the Grip.
Added the Vert Grip for looks.
doofus333
Posted - 07/25/2005 :  1:31:54 PM  Show Profile  Visit doofus333's Homepage  Send doofus333 an AOL message  Reply with Quote
Image hosted by Photobucket.com as close as i think i'm likely to get to an SR-25. it has a hardballer II barrel in there instead of the original 6 inch one, which i'm thinking of installing in the silencer, bringing the total barrel length to about a foot and a half.
Image hosted by Photobucket.com there's the chopped iron sites. i need some kind of epoxy.
Image hosted by Photobucket.com the shortened barrel. again, i need some kind of epoxy to stick that flashhider back on there.
1337_n00b
Posted - 07/25/2005 :  5:11:17 PM  Show Profile  Visit 1337_n00b's Homepage  Send 1337_n00b an AOL message  Click to see 1337_n00b's MSN Messenger address  Reply with Quote
The image “<a href=http://myspace-631.vo.llnwd.net/00167/13/67/167957631_l.jpg” cannot be displayed, because it contains errors." src="http://myspace-631.vo.llnwd.net/00167/13/67/167957631_l.jpg">
My custom M4 witha custom made silencer all ineed to do it chop the front sight and put the SR-25 flip sight and it will look the same because of the custom made barrel.
FOOL
Posted - 07/25/2005 :  5:19:25 PM  Show Profile  Visit FOOL's Homepage  Send FOOL an AOL message  Reply with Quote
Heres your pic 1337 nOOb:
Look in the discussion of photos thread. I posted in there telling you how.
1337_n00b
Posted - 07/25/2005 :  6:13:55 PM  Show Profile  Visit 1337_n00b's Homepage  Send 1337_n00b an AOL message  Click to see 1337_n00b's MSN Messenger address  Reply with Quote
Thanks i couldnt figure out how you guys put all the other pics on so i tried.
Eddy72
Posted - 07/27/2005 :  10:47:47 AM  Show Profile  Visit Eddy72's Homepage  Reply with Quote
Update on my M733.
Have any of you guys ever played the half-life mod Sven Co-op? There is a level in the game called Theyrhungry and in this level you get to use this awesome looking M4. Here is a link: http://www.svencoopcentral.com/download.php?view.355 (scroll down)
Anyway, i wanted my M4 to look like that, so here is my version:
---------------------------Update------------------------
I decided to screw the Red Dot and put back the Carrying handle. I just think the carrying handle looks better.
* Painted Body, Barrel, under the Heatshields, and the stocktab Hunter Green. (Sadly, all I had was the Gloss version, so now it looks all shiny...)
Anyone know how to make a glossy paint less shiny? I was thinking sanding would work or something like that. Any suggestions?
Page: of 2 Previous Topic Topic Next Topic
Next Page
This page was generated in 0.27 seconds. Snitz Forums 2000
