Thequestionmark
Posted - 01/25/2006 : 5:03:32 PM
Right now, I'm want to try to build a blow gun or a sling shot style weapon... Here are the requirements...
- Under 30$
- More than 100 fps
- Less than 4 pounds
What should I buy first? Would it be possible to fit hop in a blowgun? I have an extra spring pistol barrel, dunno if that would do good... |
SocalSiege
Posted - 01/25/2006 : 5:12:10 PM
| You must know..there are airsoft blowguns out there ( im not sure if i understood what it is that you were trying to assemble) but i have seen airsoft blowguns at the local sporting store for $20 |
Thequestionmark
Posted - 01/25/2006 : 5:16:10 PM
| I've seen paintball ones but never airsoft ones. I already checked the local Dicks and Garts and not found a thing. What brand of blowgun is it? |
Xplosive
Posted - 01/25/2006 : 6:42:57 PM
| Go to a hobby store, get a 6mm ID metal tube. Drill a hole in it towards the end towards your mouth, a fairly wider hole, then put a rubber band around the barrel so it sticks into the hole a bit. Next apply some tape over the rubber band to air tightify it. Start with a small hole and enlarge it to make a more effective hopup effect. |
SocalSiege
Posted - 01/25/2006 : 7:04:03 PM
| Im unaware of the brand, but it is at a Big 5 store..check their site |
Ziznach
Posted - 01/26/2006 : 8:59:41 PM
| why would you want to make a blowgun for $30, when you could buy a pretty nice pistol for that much? I mean, it's and okay idea, it just needs some power behind it. ( i mean like compressed air power) |
David West
Posted - 01/27/2006 : 03:37:37 AM
| Just stick a hand full of BBs in your mouth and blow through a barrel. Makes a fun little automatic blowgun, and ges decent power with a long barrel. |
Turahk Master of Fear
Posted - 01/27/2006 : 1:59:26 PM
| I think that a regular professional slingshot goes a helluva lot faster than 100fps. You may even have to downgrade it or not pull it so far. |
SocalSiege
Posted - 01/27/2006 : 3:17:49 PM
| i have a wrist rocket and with airsoft bb's its probably 500fps, not exxagerating, after all, they were made for killing rodents. |
Ziznach
Posted - 01/27/2006 : 3:40:46 PM
do you think you could get a link to it? or at least tell me where you goyt the wrist rocket?
it sounds cool, but idk what they are, try to post a pic if it wouldnt be too much trouble, i'm sure everyone else is anxious too. |
SocalSiege
Posted - 02/02/2006 : 6:43:20 PM
A wrist rocket is just a super highly powered sling shot, just google wrist rocket on images, itll be there on the top. |
