 Custom Guns/Modifications
 How do i put the hopup rubber back in my M733?
ElectricBlu
Banned
Posted - 01/31/2006 :  10:31:19 PM  Show Profile  Visit ElectricBlu's Homepage  Reply with Quote
I dissasembled the barrel and receiver and i pulled the hopup rubber out when i pulled the barrel out. How do i put it back in. Does it go at the back of the hopup unit or does it actually go inside the hopup unit. Like, would i put it on the barrel and pull the barrel through it or what?
d_thedj
Posted - 01/31/2006 :  10:45:45 PM  Show Profile  Visit d_thedj's Homepage  Reply with Quote
Put the hop-up rubber on the barrel and gently slide it into the hop-up unit. Once it is in, slide the locking clip over the barrel.
ElectricBlu
Banned
Posted - 01/31/2006 :  10:58:39 PM  Show Profile  Visit ElectricBlu's Homepage  Reply with Quote
Damn, i just tore it trying to slide it down the barrel.Where does this little piece of rubber go? It just came out of the inside of the hopup unit.
d_thedj
Posted - 01/31/2006 :  11:12:13 PM  Show Profile  Visit d_thedj's Homepage  Reply with Quote
What are you working on?
If it's an AEG:
It only goes over the end of the barrel with the small cut out.
The hop up rubber has a wide opening and a small opening. Wide opening slides over the end of the barrel with the square cut out. There should also be a small line of rubber inside. This line goes into the slot on the barrel. This aligns the bucking with the hole in the barrel.
New rubber costs around $5.00 at Jungle Toy.
ElectricBlu
Banned
Posted - 01/31/2006 :  11:16:35 PM  Show Profile  Visit ElectricBlu's Homepage  Reply with Quote
yeah its an m733 Tm. but you have to have a $20 minimum to order. but what about this little tiny peice of rubber that came out the inside. like a small rubber cylinder
d_thedj
Posted - 01/31/2006 :  11:25:01 PM  Show Profile  Visit d_thedj's Homepage  Reply with Quote
Get an extra set of gears for $20, or metal bushings and a new piston head, or piston.
And nozzels, everyone needs nozzels, you can never have enough nozzels. Oh, and shims, get lots of shims, everyone loves shims.
Seriously, though, check to see if they have a store near you. If that fails, send me an email. I have a store nearby that I go to atleast once a week, and I don't have a $20 min.
Edit:
You can also get a new barrel for $10.00
ElectricBlu
Banned
Posted - 01/31/2006 :  11:27:10 PM  Show Profile  Visit ElectricBlu's Homepage  Reply with Quote
but what about the little rubber thingy that came out the inside? where does that go? does it go in that little slot inside. If so, does it go in long ways or sideways?
d_thedj
Posted - 01/31/2006 :  11:43:07 PM  Show Profile  Visit d_thedj's Homepage  Reply with Quote
Look at section V24
http://www.pegatiros.com/download/despieces/riflesmarui/m16a1.gif
If it's too small to see, hover your mouse over the lower right corner. A zoom all box should appear. Click on it.
ElectricBlu
Banned
Posted - 01/31/2006 :  11:49:43 PM  Show Profile  Visit ElectricBlu's Homepage  Reply with Quote
i see the peice but it doesnt tell where it goes. i dont know, thanks for your help. ill just slap it in and see if it work and take it from there.
Rain_Man
Posted - 02/01/2006 :  01:13:50 AM  Show Profile  Visit Rain_Man's Homepage  Send Rain_Man an AOL message  Reply with Quote
it goes in the notch on the inside of the hop up assembly with the holes facing the sides of the unit
Rain_Man
Posted - 02/01/2006 :  01:14:30 AM  Show Profile  Visit Rain_Man's Homepage  Send Rain_Man an AOL message  Reply with Quote
im surprised nobody else knew that
This page was generated in 0.14 seconds. Snitz Forums 2000
