 Custom Guns/Modifications
 Is there a paint that makes plastic look metal
derrick007
Posted - 01/09/2006 :  8:59:17 PM  Show Profile  Visit derrick007's Homepage  Reply with Quote
Is there a paint that will make your gun look like black metal. its a cybergun M16A1, if that matters. this gun would look great if it wasnt so plastic lookin.
Xplosive
Posted - 01/09/2006 :  9:20:38 PM  Show Profile  Visit Xplosive's Homepage  Send Xplosive an AOL message  Reply with Quote
You could use the foil tape method and then paint over that. THat way some real metal would show through.
the ROOB
Posted - 01/10/2006 :  09:07:05 AM  Show Profile  Visit the ROOB's Homepage  Reply with Quote
there are metalic paints but you dont want to use them unless you want your gun to sparkle sparkle (you don't). you might think about spraying you gun camoflage, camo paint job took the plasticy look away from my UTG 870. now it looks just like a stubby version of my uncles boar hunting shotgun.
ROOB
derrick007
Posted - 01/10/2006 :  6:13:11 PM  Show Profile  Visit derrick007's Homepage  Reply with Quote
OMG I CANT BELIVE I DIDNT THINK OF THIS! Testors metal flake plastic model paint.
http://www.testors.com/catalog_item.asp?itemNbr=2214
i could then spray a flat clearcoat over this, so it would look like polished metal, painted black. do yall think this will work?
and i could use the red for the '70 mustang boss 302 i just baught.
AGuineaPig
Posted - 01/10/2006 :  7:31:21 PM  Show Profile  Visit AGuineaPig's Homepage  Reply with Quote
No..I think the paint will be too shiny to actually look like a gun finish.
the ROOB
Posted - 01/10/2006 :  7:37:53 PM  Show Profile  Visit the ROOB's Homepage  Reply with Quote
i will look like your gun is covered in very fine glitter, not made of polished metal.
krome
Posted - 01/13/2006 :  12:45:08 AM  Show Profile  Visit krome's Homepage  Reply with Quote
You could try using touch up spray paint for cars.You can buy the color to match the gons actual color or you can try a 2 stage effect using paint.Start by painting a metal color(chrome/silver) as your base color let it dry completely then apply a thin coat of black or dark gray(charcol color) let it dry.Make sure that if you want that worn look, apply a thin coat of the dark color and with some 2000grit wet sand paper to sand down the parts tgat the metal is showing.If the paint looks too shiney sand it or get Testor "dull" clear spray,it is used to finish off the military plastic kits and gives then an even look and dulls any shine.
Posted - 01/13/2006 :  01:19:12 AM  Show Profile  Visit TehLlama's Homepage  Click to see TehLlama's MSN Messenger address  Reply with Quote
Don't clearcoat over it -- just put more laters
If you put enough layers of flat, and then put one metallic coat finish on as almost a glaze, you can get it to look right in about 75% of all angles -- plastic will look like plastic, but it can look EXTREELY convincing.
DJMikeOz
Posted - 01/13/2006 :  01:54:49 AM  Show Profile  Visit DJMikeOz's Homepage  Click to see DJMikeOz's MSN Messenger address  Reply with Quote
Just use Krylon ultra flat black. It looks right every time. If you like Testors then try 2 parts flat black to 1 part battle ship dark grey. It will look black indoors and really dark grey in daylight. Just enough to give the rifle a very subtle two tone look in sunlight.
I used to use that mix for painting German WW2 tank models. except I would use a 50/50 mix for highlights and dry brushing, and a black wash for filling in small receses and cracks. But you can try that too if you want.
Spidey
Posted - 01/13/2006 :  04:36:23 AM  Show Profile  Visit Spidey's Homepage  Reply with Quote
That's what I use.
I even used it on my TM G36C, as it was too "shiney" for me. So I just did a light spray job on it with that, it blended nice so it looks like the real gun (which is what I was going for, not a "metal" look).
Mr. Marui
BANNED
Posted - 01/13/2006 :  05:48:57 AM  Show Profile  Visit Mr. Marui's Homepage  Reply with Quote
Yea krylon is good.
krome
Posted - 01/13/2006 :  12:34:49 PM  Show Profile  Visit krome's Homepage  Reply with Quote
It is not an easy process,I have been using those techniques(spray paints) for years.The only thing I can say is to practice,and you will see for yourself the differences that you can achieve and develope your own technique.
TheManWithThePlasticMag
Staff Writer
Posted - 01/13/2006 :  1:10:25 PM  Show Profile  Visit TheManWithThePlasticMag's Homepage  Send TheManWithThePlasticMag an AOL message  Reply with Quote
I use Rustoleum flat black over a grey primer basecoat. Looks just like metal.
Souske
Posted - 01/13/2006 :  5:48:49 PM  Show Profile  Visit Souske's Homepage  Reply with Quote
Problem is that paint wears off overtime, even with clearcoats. As someone said above, you can use my foil tape method to get the look. The challenge is applying the tape on effectively.
AGuineaPig
Posted - 01/14/2006 :  02:37:50 AM  Show Profile  Visit AGuineaPig's Homepage  Reply with Quote
Use several coats and it should last longer. Besides, if the gun is originally black and you paint it black, even if it wears off, it will give your weapon a more "combat" look.
derrick007
Posted - 01/15/2006 :  12:10:20 PM  Show Profile  Visit derrick007's Homepage  Reply with Quote
As some of you may know, i am converting my humble little M16A1 into the legendary AR-15 SP1. Eugene Stoners first, sucsesful, rifle of this design, and the gun that started the M16 dynasty. im doing this because my dad had an SP1 back in the day, when he was in 82nd airborne. he says its a cool project and is financialy helping me out with the project (he buys the paint and pays for shipping of the flash hider and 20 round mag) now, painting it in the first place will make it look more real, so i just want to get the color right. what paint should i get if i want the dark gray of the real SP1?
heres a pick of the real steel that im trying to match
http://images.gunsamerica.com/upload/976667409-1.jpg
khoops66
Posted - 01/30/2006 :  10:10:38 PM  Show Profile  Visit khoops66's Homepage  Click to see khoops66's MSN Messenger address  Reply with Quote
In past years i have used different gloss paints. This makes a sort of a "shine" that you might see on a chrome or metal object. Be aware of different brands though some paints can really get clogged and might affect the gun.
The Old Man
Posted - 02/01/2006 :  07:01:24 AM  Show Profile  Visit The Old Man's Homepage  Reply with Quote
For military style weapons, use "Sandable Automobile Black Primer". Whats nice about this type of paint is that it has a flat finish and is much more durable than modeling enamels and dries very quickly.
After wiping down the gun with water (to take off any surface oil and grit) and completely drying it off, apply three LIGHT coates of paint. Make sure each coat is dry before applying the next.
Another nice aspect of this paint is that, as the gun is handled and used, the high points take on a different texture. Just as real firearms do (such as holster wear).
If your surface gets scratched or banged up (which is also what happens with military style arms), you can easily spray over that area and you wont have to worry about "matching up" the color.
This page was generated in 0.42 seconds. Snitz Forums 2000
