 Gas Discussion
 KJW Valve tool - where to find?
Avatar22
Posted - 02/03/2006 :  7:29:45 PM  Show Profile  Visit Avatar22's Homepage  Send Avatar22 an AOL message  Reply with Quote
I own a KJW USP Tactical (and please don't just reply with "sorry") and of course I'm faced with the infamous mag leak problem and I would really like to be able to replace my valves. I've found valves to buy, but I can't find the tool itself needed to remove the old valve. I've heard of making them by dremmeling out the middle of a screw driver but I'd really rather buy the tool itself. If anyone knows where I can buy one, or any other ways of removing those valves, I'd love to hear about it.
~edit - I've fixed your slightly vague title. Check out this thread if there's any confusion.
-rantng
d0c speed
Posted - 02/03/2006 :  9:43:48 PM  Show Profile  Visit d0c speed's Homepage  Send d0c speed an AOL message  Reply with Quote
You can use two small screwdrivers at once to turn the valve. Anyway, I don't think you need a new valve, just an o-ring.
Discpl3
Posted - 02/03/2006 :  11:21:52 PM  Show Profile  Visit Discpl3's Homepage  Send Discpl3 an AOL message  Reply with Quote
all i need is 1 screwdriver to take out the valves on gas guns and i don't think you can find just the O-ring by itself.
rantng
Moderator
Posted - 02/04/2006 :  08:17:42 AM  Show Profile  Visit rantng's Homepage  Send rantng an AOL message  Reply with Quote
The valve on some mags might not be recessed enough that you will need a valve tool, although a flathead screwdriver has always worked for me. A drop of silicon oil on the o-ring solves most leaks.
airsoftgi sells the valve tool, but it is pricey at $18 - http://www.airsoftgi.com/product_info.php?products_id=462
You might have better luck at homedepot or ebay. Personally, I'd rather pick up a toolset that includes a valve key. I'm sure they have other applications than solely for airsoft valves so you should be able to find one for cheaper at a general hardware store.
This page was generated in 0.27 seconds. Snitz Forums 2000
