Drake687
Posted - 01/29/2006 : 12:17:13 PM
| I'm looking to buy scope mounts for my kj m700, and couldn't seem to find any threads on people's preferences/reccommendations for either low, mid, or high scope mounts. What is the most preferred choice for height among most players (if there is one)? Thanks! |
craiglist
Posted - 01/29/2006 : 12:29:14 PM
| I use the tall mounts. As you said though, it's all personal prefrence. |
Eddy72
Posted - 01/29/2006 : 1:14:37 PM
Low mounts are preferable for scopes with smaller Objective Lenses, such as 32mm-40mm.
However anything above 50mm will require Mid to High-rise mounts for the immense Lens size. |
Snowwolf
United Kingdom
Posted - 01/29/2006 : 1:16:17 PM
| My 50mm lens needs high rise mounts. |
craiglist
Posted - 01/29/2006 : 1:29:49 PM
| My scope has a 32mm objective and even with the high mounts i've only got like .25 inch clearence between the bottom of the scope and the rail. |
Compton
Posted - 01/29/2006 : 5:14:46 PM
Depends on the front of the scope and personal preference. If it'll fit, I like mid heights because I don't have to crane my neck akward but I can still be comfortable if I'm above where I'm aiming at looking down. Take the sights of the M16, for example. I love 'em; when I shoulder the rifle, they automatically line up. Same thing with the Steyr AUG scope. ~Matt |
Sulfuric_t2
Posted - 01/29/2006 : 10:03:25 PM
| I think it depends heavily on what type of eye protection you are wearing. If you are wearing just goggles or saftey glasses, then you can pick and choose whatever mounts look best to you. If you are wearing a full face mask, you will need tall mounts, you will prolly need to modify the mask as well so you don't have to twist your head so far. I have to wear a full face mask at the field i play at, so I needed the tallest mounts i could find for my m700 and I also needed to cut a chunk out of my mask so i could get my head lined up comfortably with the scope. |
kawasakiguy37
Posted - 01/30/2006 : 01:05:23 AM
You want the lowest mounts that:
Allow your scope to physicaly fit on the gun without hitting or something
and
Does not really get in t he way when you are cocking the bolt |
50BMG
Posted - 01/30/2006 : 06:15:40 AM
| Yes, the lowest possible is best. For an example on rings, Talley Low mounts fit on a M700 with a Nikon Tactical, which has a 50mm objective, any bigger and it would need mid-high mounts. |
Canadian_Stalker
Posted - 01/30/2006 : 07:42:25 AM
Bingo! I had medium mounts on my M24, found that while wearing PB goggles, by the time I was able to get a cheek weld and get a clear picture though the scope, the goggles were being forced off to the left, with huge dangerous gaps. I switched to high mounts, solved part of the problem. Then I went to wrap around safety goggles, since one local field allows them, problem solved. Then I moved onto Bolle 800s and no more problems at all. And when I bought my KJW M700, I automatically went with highmounts, becuase anything less would be dumb with my 3-9x40 scope. And, since you have the same gun, kee in mind you need hop up adjustment dial clearance. Fact is, no matter what scope you use (ok, within reason) you'll need highmounts anyways to adjust your hop up. |
Harenil
Posted - 01/30/2006 : 08:28:29 AM
| Remember, the higher the scope, the greater the paralax error, that being said, I use the lowest I can for the scope. |
50BMG
Posted - 01/31/2006 : 06:16:07 AM
| Bacically, Harenil has got it right. Try to get it as low to the gun as you can. |
Posted - 01/31/2006 : 06:21:57 AM
| Well, I use low mounts with my 40mm M3 -- seems to work fine. If you're stuck with a mask, odds are you're better off eating the sighting error and using high mounts regardless. |
Harenil
Posted - 01/31/2006 : 12:32:36 PM
| Yeah, if you have a mask, you really got no choice... I use Bolle T800's so, I'm fine with lows. |
Elite_Sniper
Posted - 01/31/2006 : 12:42:05 PM
| Some people use custom stocks so they can use the lowest rings. Just takes a lot of plastic works. A small section is cut out where you normally rest your mask on the stock. |
scalpel ninja
Posted - 02/01/2006 : 7:59:36 PM
| I agree with Harenil. I have a low mount on my M700 that holds a 3-9x50 scope. It barely fit with a 1/8 inch clearance, but I can still have my sun shade and covers on it. The only thing is, I have to remove the cover to be able to turn the focus all the way around from 2.5m to infinity. Otherwise, I'm limited by the hinge on the cover hitting the outer barrel. |
odiusXpopulis
Posted - 02/02/2006 : 01:39:00 AM
| Problem with the KJW 700 is the hopup adjustment knob. Currently, I have a rather small scope (I don't honestly know how large) with low rise mounts and the scope body tube is sitting on the hopup adjustment knob. You can still adjust it however, it's a pain in the arse. I would recommend rings. |
