airsoft20500
Posted - 02/01/2006 : 8:01:28 PM
| i am choosing one of these which has better range the springer or the be xm8 |
airsoftb4paintball
Posted - 02/01/2006 : 8:10:21 PM
| I would chose the Tm xm177. I know that the tm will have more range than the xm-8, but does not have full auto capabilities. If you want a strong, accurate, durable, and all around good gun then go for the Tm. If you really want a full auto gun then i would get the xm-8, but know that it isnt as powerful and as accurate. Personally i would get the TM. |
airsoft20500
Posted - 02/01/2006 : 8:16:02 PM
how about the matrix ak47 black does it have good range? i would like a lpeg that goes farther the the tm and utg ive had a utg broke(maybe a lemon). any sugestions if nothing has longer lange than the tm i will just get that
thx
Mig1
Posted - 02/02/2006 : 06:21:17 AM
I thought the XM177 was out of production, but I just checked and it is still on Marui's website. But then again so is the SG550 and SG551.
The XM177 will cost about twice as much as the XM8 and has a different hop up, body, barrel, and some gearbox differences from the non A1 based M16 series.
If you get a metal body on the XM177 you will pretty much have to rebuild the entire gun becuase you will need a new just about everything.
EDITED: Oh, I just noticed you meant the spring, not the AEG. My bad. I have no experiance with the springer, though I have had several friends with the AEG. |
sidewinder
Posted - 02/04/2006 : 10:35:54 AM
I own a BE xm8 and it is a great gun. The quality controll was a little sparadic however, so you may end up needing to put a few things back together. (a pin might fall out or something) Its power it about the same as most every springer rifle I have shot that was not a sniper style weapon, and it accuracy is the same. I would suggest the xm8 since you get the full auto option and I know it is a good gun.
With regards to the ak. I own a "matrix" full metal ak LPEG and I have no idea if it is the same gun you are talking about. The gun I have is AWESOME! The fit and finish of the gun are as nice as a mauri (i am not kidding) so considering that I would have been happy if they sent me a hollow gun. The internals are plastic and seem to be made of lower quality that the BE even, but that is ok because I am almost sure that I can put a TM gearbox in. I plan on running the thing into the ground untill it breaks and the dropping a TM box and barrel in it so I will bassically have a full metal TM AK. Oh, and the plastic fake wood furnature is very good also and it is high quality plastic comperable to the TM ak as well.
The ak's range/power is less than the BE XM8's however. About 240 fps from the AK and 260-270 out of the XM8. (Just my guess I dont have a crono) |
Professor K
Posted - 02/04/2006 : 10:58:37 AM
| The XM8 shoots 270-280fps, and has adjustable hop-up, full auto, and cheap mags. So, I'd say the BE XM8 is the best choice. |
t3hPerson
Posted - 02/04/2006 : 2:00:21 PM
| I'd definitly say get the XM8. Power of a TM AEG vs. power of a TM Springer. Though of course the XM8 isn't anywhere near the quality of a TM AEG, it still shoots about the same. |
